I cannot get DAX TX Stream to work with both JTDX and WSJT.
I am trying to transmit with both JTDX and WSJT. I have CAT and DAX Active. I am receiving FT8 Signals no problem on both programs. But for some reason, when I key the transmitter, DAX TX Stream doesn't do anything at all. And I am not getting any output power at all. The DAX TX Stream is just Gray. I don't know what to do and am getting rather frustrated with the whole thing. Does anyone have a solution to how I can fix this? I wanted to say that I am using a 6400M so I am not using the SmartSDR Computer Program to operate DAX.
Mark Griffin, KB3Z
Press the mic gain knob in to bring up the menu. Make sure DAX is enabled. You must also have DAX for Windows running.
Set DAX TX level to 48 and DAX 1 RX to 34. In DAX control panel up top make sure it is set to 6400m if using the front panel of radio. Otherwise set it to the name of the client name you are using (PC name).
Hi Dave!
That did it my friend. Thanks for the help!!
Mark
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
