SmartSDR IOS connects briefly then immediately reboots radio
I started a help ticket because I could not find how to start a new topic here. Finally found the new message button 🙄 I would have started here first if I didn't have operator error. I digress.
Smartlink is showing good test locally. Using manual port forwarding. Using Smartlink or in home Wifi address problem still exists with Smart IOS on Iphone or Ipad. Rebooted router, cold started radio.
Radio works fine at home with Win10 and SmartSDR 2.6.2
TIA! Dan
Hi Dan!
Same issue here, when I try to access my radio via smartlink the radio itself rebooted...
Have you found a solution?
My radio fw is 3.3.33 e smartSDR for iOS is the latest build available.
Marco
Hello!
The problem was related to a corrupted profile. After a factory reset the smartlink issue disappear.
Thks Ken flex-helpdesk :-)
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
