Cannot select PC mic in SSDR while 6400M client running
VE6KK
Member ✭
This is a new problem, running SSDR 3.3.33. When trying to select the "PC" TX audio option, the button flips back to MIC. Local PTT is selected on the remote PC Multiflex panel and TX DAX is not selected. The only solution is to disconnect the 6400M client from Multiflex.
Conversely, when remote TX audio on SSB is working normally and then the 6400M panel client is started, the TX audio button flips back to MIC. In other words Multiflex operation is not possible.
The PC mic is the default Win 10 recording device. Operation is normal with one client. When I try to select PC mic, I hear a packet blurp being sent over IP but the selection will not hold with both clients running. I have reset both the PC and the 6400M. Should I downgrade my SSDR to a previous version?
Any help is appreciated thanks Peter VE6KK
Best Answers
Make sure the front panel and remote PC are using different mic profiles.
you should create separate global profile which contains its own TX and mic profiles, different than front panel profiles.
Thanks Dave I will try that, I have been somewhat lazy about profiles with only the stock mike on the radio. I did suffered a major hard reset after a long period of disuse and did not restore the near default profile I had stored.
Cheers Peter0
Dave, separate mic profiles did the trick. Although i have had the 6400M for several years I have been a pretty casual user ans new to remote operation. I will get all set up for PC headset, bias and all that.
The best to you!
Peter0 -
Hi Peter,
Glad it worked out for you.
Merry Christmas!
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
