Unusual Occurance
I usually leave the PGXL powered on, however, When I am done I will put the PGXL into Standby Mode. The other night I looked into the computer/radio room and saw what appeared to be a flashing light like 3 short on and nothing and again 3 short on and nothing. I am not sure how long this was going on. Since I am not able to see the back of the PGXL I decided to turn off the the PGXL from the switch in the back of the unit. The light stopped flashing as soon as I turned the unit off. The question is what is this light in the PGXL and why was it flashing. I have not noticed any flashing since then and I still leave the power on but the unit in standby mode when not in use. I should note the unit came back from servicing in late November.
Don - kx9q
  • David Decoons, wo2x
    What light was flashing? The green fan backlighting or flashing from the NIC port in back of amp? Is it possible you had a brown out before noticing the flashing light?
    The fan backlighting is normally solid.
    Yellow for standby, green for idle, and red for TX.
  • DonS
    DonS Member ✭✭✭
    I thought it was flashing red but not sure as it was in the middle of the night when I saw it as I walked by computer/radio room so I just turned off the power switch. I didn't think there was a light on the NIC port. The amp sits on the floor so I really couldn't see where it was coming from since I couldn't get behind the amp. The backlighting can be viewed from the front as It is behind the "handlebar" in the front. I have not seen this since it first occurred. Just curious.
    Don - kx9q
