How to remotely one antenna between 2 transceivers?
n0bf
I am looking for a reliable remote coaxial switch to remotely connect a Flex 6600 or an Icom 7610 to one antenna.
I will also check out the 403A AB switch if I can find it.0
Thanks for the array solutions website. I will check it out!0
There are several different solutions.
Another is a 4O3A AB switch which is powered by 12 volts. You can use an internet controllable relay to switch 12 volts to it.
W2IHY makes a 1x4 relay that can also be switched using Internet controllable relays.
I just ordered the array solutions twopak switch because it had 80db isolation.0
The Array Solutions Twopak relay has been installed and allows me the remotely switch between my Flex 6600 and Icom 7610 using only one antenna. I use the 12 volt aux power from the Icom 7610 to change the antenna over from the Flex 6600. The Flex normally has the antenna when the Icom is off. It really works great!
- 317 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
