Stream Deck return info question
At one time I had a pretty nice XL stream deck setup. I have not used it for a while and am working via SmartLink now. I have reinstalled it and from my backup files most everything works. I used to have a few buttons that showed information. One was the active slice frequency. None of those seem to work anymore.
I don't know if I have something messed up or the programming has changed. I have tried to recreate the rest call but cant seem to make it work. Just so I can make sure I am not doing something wrong can someone share they preview URL that would return frequency for the slice. Or anything else that would display dynamic content from the radio.
Rich
kd0zv
Here you go. Make sure you reinstalled the FRStack3 StreamDeck plugin.
Thanks guys will give that a try and see if it works here.
And plugins are installed. So should be good there.
These are still not working for me.
See image below.
Everything seems to work that I send, but anything that would return radio information does not work.
Rich
What StreamDeck software version are you on?
6.0.0.17703 with Firmware version 1.01.000
Rich
Appears there is a minor version update. I just installed it and that fixed it. Dont know if its related to the version or just the reinstall.
Rich
That's why I asked. The new version has some issues, some have been fixed with the latest update.
Happy that everything is now working again.
That fixed most of everything. I used to have it return active filter width and thats not working but probably something I hosed up while trying to repair things.
Appreciate your help very much.
Rich
kd0zv
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 31 Aurora
- 233 FLEX-8000 Signature Series
- 933 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 448 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
