Best VPN for my flex
wp3a00
in Networking
I want to run my connection with VPN either by software or hardware, which VPN recommendation would be the best to use in my remote flex. Since using Smartlink I have many connection issues as happened last weekend..
Best Answers
HI,
Softethernet or Hamachi do work.
Make sure it is a OSI LAYER 2 VPN ,, most VPN´s are LAYER 3 and so not work for smartsdr.
I use SoftEtherNet
Harry DL9NDW
There are quite a few users around who have SoftEtherNet running
And there once was a good guide from a swiss flex user around, i just don´t remember the link
Harry
Ok tnx for this information...i check the both options
Before moving to a VPN solution i suggest checking to ensure the drop outs are not due to a connection issue, otherwise the VON will not make a difference.
You can also check if your router already has a built in VPN server built in, that avoids further setup. Otherwise SoftEther is a good solution.
Ok Eduardo yes I check everything before moving to VPN....tnx
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
