Radio ethernet intermittent
ANY help is greatly appreciated. 73
First thing to do is check the cables / ports that go from the switch to the radio. Cables and connections do go bad. Just on spec, replace the radio cable with another known good one. Next thing is to change to another port on the switch for the radio (assuming you have spares).
Good luck, and remember, GB Ethernet is pretty well radio on a wire :-)
Thanks for the info Ted. I have swapped out all cables, used different switch connections, replaced the switch and used different connections on it, tried a laptop with a short cable direct to the radio.....all with the same results. I was testing more, and everything works until I try to transmit. The software window for the 6600M freezes for a couple seconds, then resumes operation with the data graph at red, slowly increasing to yellow then green after 60-90 seconds.0
Hi Daniel, You may be getting RF into the radio from a different point. Try disconnecting things one at a time to see if you can identify where the RF is getting in. For a while, I had RF coming in on the cable connecting my paddles to the rig. I unplugged them and it instantly got better. I originally had a mix 43 ferrite on that line and replaced it with a mix 31. All better now!
Thanks Len, I have not had any problems with RF even running the PGXL wide open digital and voice. I did think RF, so I set the power to 0 (zero) with the same results. As soon as I hit the ATU (set to zero) or tap the MOX, it errors. This is a tricky one. I was hoping someone might have a way of resetting the internal ethernet board or if there is a diagnostic for it.0
Hi Daniel, I think I would submit a help desk ticket at this point. Flex support staff are really knowledgeable about network issues.
- 384 Community Topics
- 650 The Flea Market
- 149 SmartSDR+
- 263 SmartSDR CAT
- 287 FLEX-8000 Signature Series
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 801 Peripherals & Station Integration
- 142 Amateur Radio Interests
