Ticking the TX on slice A B or C
Ed Stallman
When I click on (TX) of one of 3 slices to transmit on that slice , is their a way for that slice to be active with the yellow diamond on that slice also ? I know I can click the tx making it red and then click again in the band pass to bring the yellow diamond to that slice also but if I forget then I log the QSO on the wrong slice .
I'm using N3FJP logging SW
Tnx Ed
If you use FRSTACK it has the ability to do this.
Larry thank you kindly . I've installed FRStack and have the red TX and yellow active moving together . I've setup all band CW memories . I think I may like the MRU stacking , we'll see . I'll learn more as I go
Tnx Ed N5DG
The memories function of FRstack are really useful. I use them in place of the profiles in SmartSDR.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
