Maestro crash
Since today Maestro will not startup completely. It gets to the point where to select software version. V 3.3.3 has been installed. In the list it shows this software version without arrow up or down.
When I select this version ( which is also on my Flex 6600) it starts to upgrade and showing graphbar (step 3 of 4)
At the same time my Flex 6600 start to downgrade! ( purple light on 6600)
Then I get error message on my Maestro. It says needs internal software update, starts to load software, and then get wait for hardware update X,Y, etc and then message "An error has occurred that requires restart of Maestro. Show more says An unhandled error has occurred. Safe handle has been closed.
After re- upgrading my 6600 to 3.3.3 again it is working fine (without Maestro)
Any ideas?
Chris
DJ2NL
Looks like after updating un downgrading couple of times suddenly Maestro starts to behave normally and logs on correctly to 6600.
So for now my problem has been solved.
Chris
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
