Removing some "Band Menu Button" options, is it possible?
I've Googled and searched the User Guide without success.
Is there a way to remove buttons for bands I don't have or use? For example, I do not want the 4, WWW, GEN, 2200, 630 or XVTR buttons as I have no use for them. I cannot find where this might be changed.
Mike KF9AF
Best Answers
Hi Mike, James is correct, there is no facility for removing any of the band buttons, except for the Xvtr bands that you add yourself.
Since you have 4 Meters showing, I would guess that you got that rig from someone in Europe. I think that if you put in a help desk ticket, they will send you a turf file for the US so that the rig will transmit on the appropriate frequencies.
Len is correct. This panel cannot be customized and it has been exactly as you show it for a long time. This is the image from the SmartSDR v2.6.0 User Manual:
You will just have to live with it the way it is.
73, Craig KØCF
I don't believe there is a way to edit things like the band buttons.
KD0RC,
It's possible this is due to just getting a new SD card from Flex due the recent loss of slice issues. I don't remember seeing all those buttons with my previous SD card. Seems odd there isn't a popup/menu with check-boxes to eliminate bands that one would never use.
Looks like I'll submit a Help Desk Ticket.
Mike KF9AF
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
