MacSSDR with 6600M
Hi all
Been using Macssdr in various configuration here with my 6600M.
itis a nice additions ot my capabilities
Inthe attached Pic i an running two slice off main screen running FT8 on 10 & 12M
and
on macssdr i am monitoring 15m and 40m SSB freqs
behind the scene are two mac mini's (intel)
you can see on main screen homekit control of all power circuits
as well as rotor control and kpa500 control...
upper right is macssdr with two lsice SSB and mldx map with spots
upper center screen with mldx mapsmonitors my FT8 copy as well as JTBridge which consolidates two slice of FT8
upper left screen is two slice of FT8 on12m and 10m
OH...there is a icom 7300 on bottom right of the pic..backup rig
Paul K3SF
Show-off :-)
Very nicely done, Paul. Shows the utility of the Mac with SSDR and a 6600M (my setup, too). I wish I had as much space for monitors in one place - mine are spread between two desks, with a K3 and 6600M on one with a NUC running Linux and two monitors. Other position is a MacMini (Intel) with two monitors - it doubles as my day-to-day computer.
I do have a question - What do you use for KPA500 control on the Mac, Paul?
hi ted
for KPA500 control, Elecraft has a mac version. .KPA Utility v 1.19.9.6
and
i use a usb to rs232 cable as interface from mac min to the kpa500
also
i use a switchbot remote power plug to turn power on/off to the kpa500
this allows for me to have remote control operations via homekit
Paul K3SF
here is copy of my station wiring diagrams
Paul K3SF
Thanks for that Paul - lots of ideas and thoughts in there.
One thing I did was use a 12-port smart switch with a couple of GBICs so I could run a fiber link from the main switch to the shack's 8-port POE (supports a Hamshack Hotline phone :-) switch (also with GBIC). Gives me some comfort that no lightning or power surge comes in on the Ethernet.
hi Ted
i too would like to add more protection for surges...and lighting
future plan is to add opitical fiber from FIOS Router to the rest of the net work
and
more surge protector on power lines
right now i can easily just unplug.. i am lighting adverse ;-O
as my remote operation is more casual mode
like pedestrian mobil when walking the dog or out running errands in the car
or
Doctors visits and sitting in the waiting room ;-)
right now my next task is to add remote control of the 2x6 antenna matrix switch
OH this station was built up over quite a few years...
Paul K3SF
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
