SSDR 3.3.32 cannot find 6400 on first startup
This seems to have begun a month ago.
W11, latest, I5-11600K, Intel MB, 16Gb
6400 direct Ethernet from computer to radio (no network)
DHCP IP Radio 169.254.171.185 DHCP NIC 169.254.141.58/16
If the computer is running and I start the radio, wait for solid green, then start SSDR it reports that now radio is found. There are no intermediate devices between the radio and the NIC. The Ethernet cable is 4 feet, cat 6.
Now, leaving the radio on and restarting the computer results in SSDR finding the radio and running normally from that point on regardless how many times I may shutdown and restart SSDR. The computer is running normally with all virus and firewalls active. SSDR reports 0.0% dropped packets.
So: It is a one time event when SSDR has been shutdown and the computer has been running overnight and the radio has been shutdown overnight. At no point in the above sequence is any transmitter in the shack keyed. Its not RF.
I have S/D virus and malware and the firewall to no effect.
I suspect W11 or the NIC not SSDR or the 6400. W11 security hardware?? I don't know enough.
This falls under annoyance rather than critical problem. But it is curious.
Anyone ever encounter this type of behavior?
One possibility is that you have the PC and the radio on different subnets. The computer is on subnet 141 and the radio is on subnet 171. Try changing the radio to the same subnet as the computer. I may or may not be correct on this...
73, Craig KØCF
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
