SSDR v2.80 SSB VOX must be reengaged for Ch B after going split?
Larry W6UB
If you are using slice A with VOX engaged and then enable slice B, VOX turns off but indicates it is still on. In order to engage slice B with VOX, the VOX must be turned off, then turned back on in order to use VOX on slice B. Now engage slice A and VOX will follow from B to slice A.
If you are using slice A without VOX and then engage slice B and before enabling VOX, no problem. And VOX will follow back to slice A, as expected.
Larry
I've noticed this when just changing bands.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
