SSDR v2.80 SSB VOX must be reengaged for Ch B after going split?
Larry W6UB
If you are using slice A with VOX engaged and then enable slice B, VOX turns off but indicates it is still on. In order to engage slice B with VOX, the VOX must be turned off, then turned back on in order to use VOX on slice B. Now engage slice A and VOX will follow from B to slice A.
If you are using slice A without VOX and then engage slice B and before enabling VOX, no problem. And VOX will follow back to slice A, as expected.
Larry
I've noticed this when just changing bands.
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
