Antenna change on streamdeck?
Hi all
I have setup a series of buttons which call multi actions in streamdeck to change band.
Band
TX Ant
RX Ant
Mode
Dax Channel - RX DAX
I am finding when pressing these, sometimes the TX Ant is not correct and being the opposite of what the action should be doing. My feeling is it's still remembeing what the antenna was on the previous use for that band - as when you change bands it will set was was in use previously.
This is one of the reasons for using a streamdeck so I can ensure when moving bands, all settings are as I want. I have a 6600M and use it for SO2R so need to ensure slice a is always using antenna 1 for rx and tx and slice b always uses antenna 2.
If I press the button again, the TX or RX Ant is then correct (I see it change on the front panel), so it's not the action behind the button thats wrong, though I have checked all of the actions anyway.
Has anyone else seen this?
Is there a specific order the actions should be placed in?
Rich
Maybe too many commands all at once, try sticking a delay between, commands, experiment with like 100ms and go from there.
Thanks Mike, tried 100 and still happened to upped to 200 and so far so god so will see how it goes.
Cheers for the tip.
Rich
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
