flexradio 1500 sur linux mint
ON3RLD
ON3RLD Member
edited September 2022 in FLEX Series (Legacy) Radios
Bonjour,
j'ai un flexradio 1500, je suis sous linux mint est-il possible de le faire fonctionner?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Answer ✓
    Hi ... If I read your comment correctly, you are wondering if your Flex 1500 will work on Linux. As far as I'm aware, the only software that works with the 1500 is PowerSDR by ke9ns. I don't believe there is a linux version of his software available.
    I'm also a little doubtful that there would be the necessary Firewire drivers, etc. available on Linux.
    Sorry.
