TGXL will talk to Yaesu FTDX101MP
W2PP
Member ✭✭✭
have the baud rate set to 4800 for each, using F to F DB9,
I think I had a bad serial cable at first they do talk to one another.
Peter
Are you using a straight through or crossover cable?
Dave
I realize this is a less than clear posting. Initially it said "will not communicate" but I found I had a bad cable and eurica they do communicate. Yes its a straight DB9 to DB9 not a cross over.
Peter
Ok, good. You found the issue.
I posted another reply on how you can split your CAT.
73 Dave wo2x
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
