TGXL will talk to Yaesu FTDX101MP
W2PP
W2PP Member ✭✭✭
edited September 2022 in Tuner Genius XL
have the baud rate set to 4800 for each, using F to F DB9,
I think I had a bad serial cable at first they do talk to one another.
Peter
  • David Decoons, wo2x
    Are you using a straight through or crossover cable?
  • W2PP
    W2PP Member ✭✭✭
    Dave
    I realize this is a less than clear posting. Initially it said "will not communicate" but I found I had a bad cable and eurica they do communicate. Yes its a straight DB9 to DB9 not a cross over.
    Peter
    Ok, good. You found the issue.
    I posted another reply on how you can split your CAT.
    73 Dave wo2x
