Yaesu Band Data Interface Cables for PGXL flex Amp
wp3a00
I need to know what cable I can buy or where I can get it to connect my Flex PGXL to a Yaesu FT-101MP
A BDC cable can be constructed from a network cable. Amazon sells the appropriate connectors that use ****-type terminals, with no soldering required. I also ran my PTT down this same cable, as the BDC only uses four wires; the rest can be used for other signals. You don't have to worry about the PGXL. It's optoisolated and won't overload the 101's connections in any way. Just make sure you put a few ferrite cores on the ends of the cable.0
Ok thanks for the information I will verify those materials and try to create them and put them to work thanks again for the information
I had problems connecting FTDX101MP BCD connection to both my Antenna Genius 8 x 2 switch and Prometheus DX2400L1 amplifier (parallel connection). The solution was insertion of 1.5K ohm resistor in series with each of the 4 BCD signal wires to the amp. Both Amp and switch were optically isolated, so I assume this was an issue with overloading the sink current capability of the Yaesu rig.
73, Dewey, WØYWW
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
