Restore Preferred Preferences
K1ESE
Member ✭✭✭
I find I need to do a factory reset from time to time when my CW timing gets messed up. I export my Profiles except for Preferences since they may reintroduce problems after I reset and restore my Profiles.
I have to reset the display settings. Specifically, AVG, FPS, and Rate as well as panadapter span. My preferred preferences are AVG=75, FPS=20, Rate=60, span= 10kHz.
Is there an easy way to reset these options all at once?
Not at the rig, but I believe FRstack memories contain these, or at least most of them. Because of the auto-save “feature” of the profiles, I use stacks memories for everything. The memories capture many more settings.
John -
Thanks for the tip. I will work with FRstack.
73 de K1ESE
John
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
