nDAX "Killed"
So I'm running nDAX on a raspberri pi. Sir, you are a godsend for creating..thank you.
I am having an issue however. Randomly nDAX quits in terminal and says "killed". Then I restart it and it has an error, then starts working again. I can't reproduce it, but is usually after an hour or so of it running. Is it an idle time out or something possibly?
./nDAX-linux-arm -station Flex -slice A -daxch 1 -source flex.sliceA.rx -sink flex.sliceA.tx
1:08PM INF Waiting for station station=Flex
1:08PM INF Found Client id=0x5C7BB1FD uuid=7FE86A15-A08F-4B8A-A531-66B11E91526E
1:08PM INF Looking for slice slice_id=A
1:08PM INF Found slice slice_idx=0
1:08PM INF Enabled RX DAX stream stream_id=4000009
1:08PM INF Enabled TX DAX stream stream_id=84000000
Killed
pi@raspberrypi:~ $ ./nDAX-linux-arm -station Flex -slice A -daxch 1 -source flex.sliceA.rx -sink flex.sliceA.tx
11:03PM WRN source flex.sliceA.rx exists but was created by an nDAX process that no longer appears to be running. Will try to unload... module_index=27 pid=1041
11:03PM WRN sink flex.sliceA.tx exists but was created by an nDAX process that no longer appears to be running. Will try to unload... module_index=28 pid=1041
11:03PM INF Waiting for station station=Flex
11:03PM INF Found Client id=0x5C7BB1FD uuid=7FE86A15-A08F-4B8A-A531-66B11E91526E
11:03PM INF Looking for slice slice_id=A
11:03PM INF Found slice slice_idx=0
11:03PM INF Enabled RX DAX stream stream_id=4000009
11:03PM INF Enabled TX DAX stream stream_id=84000000
Killed
Having the same issue here.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
