Getting Stream deck to work to a remote FRSTACK computer.
Evening, I have a small server running at my remote site running FRstack. I have the ports forwarded and confirmed and have a static ip address but can't seem to operate my stream deck remote. when i do it in house and use 127.0.0.1 it works fine.. Any thoughts.
From FRStack REST API help:
Calling REST API from other Clients
The REST API are restricted by default to Localhost. This can be change by editing the FRStack.exe.config file.
Set the <add key="LocalHostOnly" value="false"/> which allows other clients to call REST APIs.
By default any client can now call the REST APIs. You can restrict the clients to by their IP address.
Set the <add key="WhiteListedIPAddresses" value="192.168.1.123,192.168.1.124"/>
Note : If FRStack is running as a User and not Admin, access is denied to http.sys. To solve:
- run FRStack as Admin OR
- config access by running as Admin: "netsh http add urlacl url=http://+:13522/ user=everyone delegate=yes""
Make sure you create an inbound TCP Firewall rule for your REST API port, 13522 is the default port.
I’ve used Stream Deck and FRStack on my laptop at Xenia controlling my station in New Jersey. I did a demo there. For me, it involved installing the Stream Deck and FRStack software on my laptop.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
