Replacement Fan for Flex 5000a
jerryco
Member ✭
The fan on my Flex 5000a is making noise. It is noisier for the first two minutes after startup and then gets a little bit quieter but I think it may be time to think about a replacement.
Does anyone know where I can obtain a replacement fan for a 5000a?
Thank you - Jerry
Thank you - Jerry
Best Answers
Although I don't think Flex directly supports the 5000 any more, it might be worth a call to them (or submit a Help Ticket) to see if they could at least point you in the right direction (i.e. specs for the replacement).
5 -
If it were me I'd look at the fan to see the make and model as a starting point. Then see if the manufacturer still make the same model or find an equivalent model from the same or different manufacturer.
5
Thank you very much Don and Geoff! I will try your suggestions. - Jerry0
This should be an ok fit for the 5000a fan.
AeroCool Shark 140mm Blue Edition 140mm Case cooler - Newegg.com
The fan will plug right in, you just need to elongate the holes for mounting.
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 14 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 899 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
