After the FLEX6600M is upgraded to 3.3.32, the CAT port is gone?
BG5ILX
After the FLEX6600M is upgraded to 3.3.32, the CAT port is gone? N1MM can't control FLEX
If you are, as you should be, conducting periodic back-ups of your computer see if C:\Users\computer-name\AppData\Roaming\FlexRadio Systems is included. From there take the CAT.settings file and copy it to the working directory to restore CAT as it was before the upgrade.
Alternatively, use a Restore Point and roll back to before the upgrade, save the Flex settings, reinstall 3.3.32 and copy back the saved settings.
Alternatively, and most simply, recreate the missing port for N1MM - it will take just a few seconds to do.
Thank you for your help🤩
-1
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
