Is there need to update to 3.3.29 before moving on to 3.3.32?
Is there need to update to 3.3.29 before moving on to 3.3.32? Just a little nervous about hitting the update button, thanks, John
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited June 2022 Answer ✓
    No need to go to 3.3.29 first ...
    However you should upgrade to 3.2.39 before upgrading to 3..3.32
    From the release notes...
    "IMPORTANT: Upgrading to SmartSDR v3.2.39 before Upgrading to SmartSDR v3.3.32
    If you are running a version of SmartSDR less than v3.2.39 , you must upgrade to v3.2.39
    before upgrading to this version (v3.3.32).
    3.2.39 and 3.3.29 is confusing...
    AL, K0VM
