WSJT-X no longer decodes
My WSJT-X doesn't decode, it's very frustrating, I'm using Flex 6700
latest software version, i use windows 10.
everything is configured perfectly but the signal looks dirty or distorted in the wsjt-x cascade could someone help me?
I uninstalled and reinstalled all the software I also tried to change the PC by reprogramming everything but nothing does not decode.
thanks for help
How are managing your Computer Time ?
I use a BktTimeSync program0
You could, just out of interest to see if there is any difference, install JTDX https://drive.google.com/file/d/1Fng2Zn6NS2tEh-qxttx-FJ9H1Ey97vji/view?usp=sharing
These are the settings, which I expect you know anyway:
If JTDX works, you know you have a WSJTx problem. If it doesn't, something is messed up in SmartSDR like DAX levels or some other.
When WSJT-X stops decoding and you see the fuzzy signals in the WSJT-X waterfall its because DAX is corrupted. You can usually close DAX and restart it to temporarily fix it. I had this issue bad with my 6700, it would distort very quickly taking the enjoyment out of operating. When I did a fresh install of windows 10 pro about a year ago, it fixed my issue for quite a while until one day it started happening again. My PC is a Dell XPS 8930 and I was able to trace the problem to a Dell App called "Dell Support Assist" that I installed way after the origional Windows 10 pro refresh. I used the free app called LatencyMon to find my issue and that was the app that caused the highest DPC issue.
Thanks Larry and thanks to all, I'm sure the problem is DAX and when I use TVr in FT8 This own does not encode despite the strong signals caused by ES from this period, I hope I will be able to solve it, I was happy with my setup. I will be present at Messe in Germany this end of the month, hoping to find Flexaradio and get some advice, I will be forced to change the infalcaso setup because it is not very reliable for a professional job.
thanks 730 -
If you have proven it is DAX by a logical method, such as the one I described, then action the instruction here:
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 955 Third-Party Software
