How to Display Call Signs on Flex 6600M Front Panel Spectrum Display
Can someone point me to a simple description of how to display spots on the Flex 6600M Front Panel spectrum display. I am an active N1MM+ user and often use the bandmap in N1MM+. I've done a lot of searches and not come up with anything.
I do have SPOTS enabled on the 6600M Menu but I assume there is some other things I may need to do in the interface between the Flex, N1MM and TELNET (?) to make this happen.
Any insight appreciated.
Al, K0AD
