How to setup for a Straight Key
BigFish30
What do I turn off in order to send a straight key.
(1) Have you disabled Iambic in the Phone/CW tab of the main 6600M menu?
(2) Have you checked the key’s wiring against Sec 7.3.3 of the 6400M/6600M User Guide?
Per the Hardware manual:
Does that help?
There are a couple of ways to set up a straight key depending on what equipment you are using. Can you post what model of radio, and whether you are plugging your key in to a Maestro or the radio itself?
I have a 6600M, with the key plugged into the back panel.
From SmartSDR turn off iambic:
From the front panel or a Maestro turn off iambic:
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
