PGXL time out after say 10 s or so when remote modem interrupts connection?
Has anyone implemented a PGXL time protection, or experienced, an interruption in the remote connection while sending 1 kW with PGXL?
Flex Smart SDR had this 1 min (minimum) timer option that can be used but sending a kW for a minute seems unattractive.
I have never seen that with my PGXL at or above 1 KW on bands from 160 thru 6m. I run mostly Digital modes, but do contesting on SSB and CW. It sounds like you have RF getting into your network equipment or cables.
Hi, no it has nothing to do with RF entering the equipment. In 5G that I use the cells change bands quite frequently and in this case they may change the external IP as well. You can confirm this with a DNS servet at the radio.
All this applies to remote radio operation over mobile access.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
