Noise reduction ?
I read some old community discussion on NR and also watched the videos that Tim and Mike created on AGC-T. I don't have a lot of noise in my area , no nasty line noise or anything. I'm just intrigued that when I click on the NR button I notice no change in noise at all. Regardless of RF Gain settings in my 7610, Flex 3000 and other past radios, I always noticed SOME change. Is my experience with NR on the 6400 with latest SmartSDR normal ?
Band I was testing things on today was 15M.
Andy K3UK
On the slice flag, you can select DSP. If you click it, do you alter the NR level? (0-100). If you just click NR on the general control panel, it will only perform the default or previous setting. I fell into the same trap some while ago, and quietly discovered my mistake! If you have not already done so, give it a go. It should work fine.
73 Mike G4GWH
Higher bands have lower noise levels. Maybe try the same experiment on 80M. Then vary the nr control to hear the changes.
Thanks Mike. Earlier today, before I saw your answer.. I saw the NR adjustment slider under DSP and that made a big difference. I use to know all this back when I had a 6300 for a couple of years. I have forgotten a lot in the 4 years of not using SmartSDR
Andy K3UK
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
