3.3.29 up and running successfully
Just wanted to report that the install of v3.3.29 from 3.2.39 went smoothly on my 6700. Running on Windows 11 Pro homebrew computer. I am reporting this as I was seeing others post problems and was quite hesitant to take the plunge. I am relieved it went well. I am not posting this to brag, just wanted others to know of a positive install experience so they can make an informed decision. Hope this helps someone.
73 Steve N3MX
It is also up and running for me. No issues on my install and seems to be running stable. I will report back if I find any issues.1
Same here with my 6600M. Installed with no problems. Several months ago I had to replace the SD card as my radio started doing some odd things.
I feel that the problem a lot of people are experiencing is because of the new procedure mentioned in the Release Notes, about the new software formatting the SD card before finishing the update. I think the original SD cards have issues that cause them to fail at some point in the update. Hopefully, Flex Radio will get this sorted soon.
6600M successfully loaded first try.
Went fine here!
Dave KC9EI
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
