TCPIP command to turn CW sidetone on or off
I'm playing around with Node-RED and looking for TCPIP commands that will turn the CW sidetone on and off.
transmit set mon_gain_cw=6 (from https://github.com/flexradio/smartsdr-api-docs/wiki/TCPIP-transmit) will set the CW monitor to a level of 6, for example, but if the sidetone has previously been turned off it this command will not turn it on. It appears that sidetone level and sidetone on/off require 2 different commands.
Suggestions appreciated.
Tim K9WX
Hi Tim, the commands are:
"CD95 | cw sidetone on" "CD95 | cw sidetone off"
Len
I Wire Sharked it and found:
"cw sidetone 1"
"cw sidetone 0"
Perhaps the same as "on/off"
Alan. WA9WUD
Hi Alan, The documentation says "on" and "off", but "0" and "1" works just as well.
Where might I find this documentation? Is there a resource other than https://github.com/flexradio/smartsdr-api-docs/wiki/TCPIP-transmit
Tim K9WX
Hi Tim, that GitHub wiki is the only source of the API documentation that I am aware of.
Home · flexradio/smartsdr-api-docs Wiki (github.com)
Scroll down and see all the categories of commands:
Click on the command name to get all the variants. For example, Click on CW and there you can find the sidetone on/off commands. Sometimes the commands are not where you expect them, so some poking around is usually required to find what you are looking for.
Thanks, Alan and Len. That works. And Len, yes, I am learning that the commands are not always where I expect to find them.
Tim K9WX
I guess that it is not too surprising, given the complexity of the 6000 radios and the enormous number of commands they support. It is a bit like learning a new language - at first the grammar and syntax doesn't make much sense, but then as you get to know it, you start to use it without much struggle.
My biggest epiphany came when I discovered binding my non-GUI Client application to a GUI Client. All kinds of things became available after that!
- 337 Community Topics
- 605 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 401 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 185 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 952 Third-Party Software
