no audio in SSB mode
Sergey KN7K
Member ✭✭✭
I probably did something last night and feel **** that cannot figure it out.
Tried to listen today some SSB on 6600 and found there is no audio on any band when either in LSB or USB. There is an audio in CW and audio level is good.
So far I have done the following:
1.Check on both Maestro and SSDR-same issue.
2.There is no Mute on upper right corner Speakers or Headphones settings.
3. SSB widgh 2.4khz or above.
4. AGC on Max.
5. Same on 3 different antennas.
6. PC restarted
7. If I do SSB recording, I can play it back. Just no live aduo
Can someone point me to a right direction?
Sergey, KN7K
Edit, I actually have audio in CW mode only, no any other mode procuse an audio
4. AGC on Max.
6. PC restarted
Sergey, KN7K
Is it the same on both antenna ports? A and B Is your antenna selection correct?0
same on all antennas, Ant1 steppir, Ant2 50mhz 6el.
No noise, no nothing at max volume0 -
intersing glitch. I was planning to do a factory reset, but before that I just restarted radio once and issue is resolved.
Sergey, KN7K0 -
"Interesting Glitch" indeed! It's still there, buried somewhere, as I just had the same thing. NO AUDIO out in any form (none via DAX, PC Speaker, nor speaker from the 6600 directly), but the waterfall shows normal (in this case, FT8) signals. CW was the only mode that produced an audio output. Was at my wits end when I found this thread, and sure enough, power off the 6600 (via the switch, no need to actually remove power), and then back on, and all's well. Would hate to have that happen during a contest!0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
