Can not login,
I set up an older Windows7 computer with the hopes of using the SDR software. After some difficulty, I was able to activate Net4.6.2 after some prolonged effort and manipulation as SDR would not install without this. The SDR seemed to be properly incorporated into the computer with virtual COM ports and audio ports identified with Control Panel. Starting CAT, for example, produces the login page. Entering the proper username and password produces NO response in the window. The Flex radio is ON. My Maestro can connect. Repeat, I am using the proper username and password. Any suggestion? I did reload the SDR software adn that offered no change in the response.
It could be Windows Firewall blocking SmartSDR from connecting.
Yes, James. I thought of that too. I disabled Windows Firewall and found that made no difference. I just got back from the remote location. The radio and computer there are working without obvious problems. I turned the radio off then started CAT again. It asked for my username and password, then paused for 10 sec and identified me. So, that is further verification that my password, etc was correct AND there is no larger Smart SDR failure. I hope someone else comes up with another idea. Thank you.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
