equalizer settings ??
K0FG_Fred
This on a 6400M with v3.2.39, front panel, not ssdr. Most of my operating is cw and I would like to use the rx eq settings to tailor the rcv audio. I looked at the rx eq settings in cw mode and then in ssb mode and they were the same, don't think that will work, don't want to boost 500-1000 settings in ssb mode. If I change one it changes the other too. Do we have separate rx eq settings for cw and ssb modes?
Why do we use tx eq in cw mode? Or is it automagically turned off when using cw even if the enable button is on?
Fred, K0FG
Fred, K0FG
For CW I just reduce the bandwidth of the received signal. Makes it nice and sharp and as penetrating as I want. Nice and easy!
Not sure about the rest…..
73 Mike.
With the narrow bandwidth for CW, there is no need for audio equalization. I use 400 or 250 Hz for most of my CW operating, and this is narrower than the spacing between the three audio bands involved: 250, 500 and 1 kHz. I use 550 Hz as my CW pitch and center of the passband, so AF is from 350 to 750 Hz. Equalization simply doesn't add anything to this.
73, Craig KØCF
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 979 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
