6400 using 2 transverters
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
edited February 2022 in FLEX-6000 Signature Series
What schemes has anyone configured to use 2 transverters with a 6400?
Added:
Does anyone have experience with New Tohtsu CX-230 SPDT with 3 x BNC RF Connectors Coaxial Relay 12 VDC Coil?
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    You can simply use the tx outputs per band to control the transverters. You can use an RF relay tied to those same tx outputs, or use an RF splitter / combiner for RF to/from the transverters to the single transverter in/out on the 6400. The transverter output is low enough level it should not bother the transverter that is not in use. Of course it is simplex :-)
    I’m sure others will also come up with similar solutions.
  • Geoff AB6BT
    Thanks Ted.
    That's my first take as well.
    I can build a bjt/fet driver for the relay and drive it from either a tx output ot a USB-bit pin.
  • Geoff AB6BT
    I've got a couple Mini-Circuits ZFSC -2-1B splitters.
    I also have a BNC coax relay. I'll try both as see what works better. The advantage of the splitter is there is no active switching and asociated circuitry involved.
    Trials soon...
