Do the internal speaker and external speaker (jack) remain enabled when a headphone is plugged in?
Mike, KE4U
Member ✭
I use a headset with electret mic, external speakers and a dynamic mic. I will have to build or buy a mic switch since I understand there is a single mic input on the 6400M.
However I am curious if the internal speaker can be set to remain active while there is a headphone plugged into the headphone jack. As an add-on question does plugging in an external speaker silence the internal speaker?
Both the speakers and the headphone can be active at the same time.1
Thanks Tim0
Now that I have a 6400M, I note that both the speakers and the headphone are active at the same time. A follow-on question: how can I mute the 6400M internal speaker when I plug the headphones in the rear-panel headphone jack per 29.3 of the User Guide?0
The only way I found is to goto the menu and select the Disable box for the Front Speaker to turn it off.
Hello
I s the Flex 6400m external speaker is stereo so it needs 2 speakers and active..???0 -
The powered speaker output is a stereo 1/8 inch jack, so yes, you would normally use stereo, but I’m sure you can listen to left or right, or merge them externally.0
any particular make of speakers recommended tnx
Hi Arnold, I have the Creative T10 speakers that I found on Amazon. They seem to be reasonably RFI resistant. They are rugged enough to bring to Field Day (they have a metal grid over the speakers). Some speakers have an unprotected speaker cone, so watch out for that. They sound great and have plenty of volume. I use one of the cheap ground-loop breakers that I got on Amazon. It is just a 1:1 audio transformer and costs in the vicinity of $10.
I started with some old, no-brand amplified computer speakers and they were unusable on some bands due to RFI and they did not have much volume.
I hear good things about the Bose speakers, but I don't have any experience with them.
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 954 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
