Q5 5BVUX via the FTDI USB cable
n0yk
Hi Group -
Just got my FTDI USB cable in from Q5. Trying to get it going but just not finding enough documentation on how to make it all work.
I have configured it under the USB cable settings menu as follows:
Cable Type: BCD
Source: TX Slice
Type: VHF_BCD
Polarity: Active High
I also have the 5BVUX connected to my 6400M via the transverter port and have the 5 bands configured via the transverter menu. I'm not having any luck getting it to switch the 5BVUX between VHF bands.
Would anyone be willing to share their configurations that make this option work?
Thanks!
Chad
N0YK
Cable Type: BCD
Source: TX Slice
Type: VHF_BCD
Thanks!
Chad
N0YK
Just a follow-up to my post about the Q5 5BVUX mulit-band transverter. I was able to get the USB cable working and it works great. Has turned my 6400M into a 160M through 1296 MHz transceiver with 902 MHz!
Steps via SmartSDR:
Click "Settings" and scroll down to "USB Cable". Edit existing default cable profile to the following: Name <whatever you want>, Serial <auto-populated by cable type>, Cable Type <BCD>, Source <Tx Slice>, Type <HF_BCD>, Polarity <Active High>.
Once you have this setup, the Q5 transverter will follow any of your preprogrammed transverters for 144, 222, 432, 902, and 1296 MHz.
4 -
bcd_vbcd was the option that worked for me in SmartSDR for iOS. Otherwise all other settings are the same. Thanks!0
- 369 Community Topics
- 628 The Flea Market
- 84 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 915 Genius Products
- 332 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
