Tuning a RTTY Signal on a 6400M
Good Evening.
I have been playing around with MMTTY and my 6400M on this weekend's RTTY Contest. OK, I see the RTTY signal which is like the letter U on my screen. But the question is where do I place the A Slice yellow line to copy the signal. Is it in the center, to the right or to the left of the U? I am using DIGL. Thanks!
Mark Griffin, KB3Z
I don't have a 6600M but a 6600. I don't believe the 6600 will decode RTTY itself, not sure about the 6600M. For the 6600, you need to feed the audio from the radio into a decoding program. MMTTY is the most common and, for MMTTY, you want to put the radio into RTTY mode, not DIGL. When in RTTY mode, SSDR will show you 2 yellow lines which you will align with the two peaks of the RTTY signal.
Tim K9WX
Tim,
That is interesting because on my 6400M I can operate and not use the SmartSDR program. Other than CAT and DAX. I did not notice RTTY as a mode choice on my 6400M. So can I safely assume that it is only a function of using the SmartSDR program?
Mark KB3Z
I can switch to RTTY mode using the screen of the Maestro.
Tim K9WX
Thanks Tim!
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
