New firmware install problem ... v3.2.39
I am using SmartSDR for Mac to update the firmware in my 6600 from v3.2.34 to v3.2.39. The firmware downloads correctly and upon installation SmartSDR for Mac issues a dialog box stating 'Upload was successful'. The 6600 reboots, flashing green, but ultimately flashes red three times as a boot failure. Power off and on, boots back to v3.2.34 and is operational. Of course, my main objective is to update the firmware and that has failed.
Any ideas, or similar observation? I am hesitant to use my Windows laptop for the update, as I don't want to go down that path and the potential .NET complications. I never will use SmartLink so I have not bothered to update till now, when Marcus suggested that I do so in addressing a separate issue.
W7NGA
I also found I could not import my saved profiles and config using SSDR for Mac. Resorted to using SSDR on Parallels.
I guess the larger question is ... has anyone successfully installed v3.2.39 using SmartSDR for Mac?
There is a known defect with 3.2.34 that can lead to corruption of the memory card.
I suggest opening a Help Desk case with support.
If this is the MAC software and the Radio still powers up and works with the older MAC version then this MAY be different then the SDCard issue and you may want to check with Marcus on this problem who wrote the software.
What version is on the Radio itself if you happen to have a windows machine can you update the radio to V3.2.39 then give the MAC version another try?
Just a thought
Using SmartSDR for Mac to update the firmware to v3.2.39 yields the boot failure. Doing a Factory Reset also shows a boot failure and then boots up v3.2.34 which is the version the radio came with from the Factory. I am submitting a support ticket.
Thanks for the responses ....
How was this problem finally resolved?
Was it a radio problem?
Was it an problem with mac-ssdr?
Inquiring minds want to know..
thanks....Paul K3SF
I received a new SD card from Flex and loaded the firmware using my Windows PC. It updated correctly and I lost interest. I was never able to update the firmware with SmartSDR for Mac successfully. Once I had the new firmware installed I was hesitant to experiment with the Mac in fear that something may get corrupted.
- 385 Community Topics
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
