IC-705 PGXL Settings/Cabling
mastersond
Trying to figure out how to cable and configure my IC-705 with the PGXL. I am using the Icom remote utility with the A4H CI-V setting to remotely connect to the radio over WLAN. I have the 3.5mm to 3.5mm cable connected to ALC on the radio and the CI-V 3.5mm jack on port A of the amp. I do not see an ICOM radio in the PGXL utility that would map to the IC-705 or any CI-V options that are available on the IC-705. Guidance on this configuration would be greatly appreciated.
You need to change the default CI-V in the 705 to a default CI-V for one of the radios listed in the PGXL.
Thanks Chuck0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
