JTAlert both WSJT-X and JTDX simultaneously
GM Gents , I've used multiple instances of WSJT-X and JTAlert for quite some time all works fine . Now I'm comparing WSJT-X against JTDX and have no problem using both simultaneously ! The problem I'm having is using JTAert one for WSJT-X and one for JTDX.. I can do one or the other but not both . Doing a search , I came across a HamApp IO-Group message dated 2018 saying this was not possible . So this may still be the case ? I did send a message to HamApps but no reply at this time .
Thanks Ed N5DG
From the HamApp IO Group
Running multiple copies of JTAlert against both WSJT-X and JTDX simultaneously is not supported. You can run multiple instances of JTAlert against either WSJT-X OR JTDX only. Both types of applications can be running simultaneously on the PC, but only one JTAlert operating mode (against WSJT-X or JTDX) is allowed.
de Laurie VK3AMA
HNY all , Ed N5DG
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
