Got TGXL today
I have it installed and wired up. Seems to be working well.
I was hoping it would be able to tune a 40m vertical on 20m but it can't. Oh well that would be a sucky ant anyway. I was hoping it would tune for backup purposes if my 80m loop goes down.
I am running SmartSDR Mac and I notice that the tune button in SmartSDR does not engage the tune feature of the TGXL. I assume that is intended.
Anyway, it is pretty much a plug and play device. Will report more as I learn more.
  • N0EG
    N0EG Member ✭✭
    I've found that the tuner will easily tune a MUCH BROADER range manually than it will automatically. Which gives me hope they can fix some stuff via software.
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    Interesting... I'll have to give that a try...
  • Mark_WS7M
    Ya... I was able to tune my 40m vert on 20m manually. Again not sure that will be a great antenna but the fact that the tuner can do it lends hope that software can be improved to do so.
  • K4QXX
    K4QXX Member ✭✭
    The tuner needs some work on the auto tune but I have been able to manually tune everything so far. Auto tune will probably get better with future firmware updates.
    K4QXX
    Burch
