Which SmartSDR should I download
It's been a couple of years since I have had a Flex radio so I'm a little rusty. I bought a used 6400 yesterday that had been use only on a Mac. I will be using Windows 10. Are the versions 2.x considered maintenance and free? If these are free, which version should I go with?
  • ka9ees
    ka9ees Member ✭✭✭
    Depends on which version is in your rig. Current version is 3.2.39 and 2.7.6. I don't know which #1 version is.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    If the flex has a V2 version installed, a later V2 version will be free. If it has a version of V3, a later version will be free. If it has V1 or V2 and an upgrade to V3 is desired, that cost $200.
  • Roger Miller
    Roger Miller Member ✭✭
    Thanks John, I think I will play around with a free version till I make up my mind about the radio.
  • John KB4DU
    edited December 2021
    Good idea.
    the only real difference is that the v3 allows multiple ops to connect at the same time.
