Which SmartSDR should I download
It's been a couple of years since I have had a Flex radio so I'm a little rusty. I bought a used 6400 yesterday that had been use only on a Mac. I will be using Windows 10. Are the versions 2.x considered maintenance and free? If these are free, which version should I go with?
Depends on which version is in your rig. Current version is 3.2.39 and 2.7.6. I don't know which #1 version is.
If the flex has a V2 version installed, a later V2 version will be free. If it has a version of V3, a later version will be free. If it has V1 or V2 and an upgrade to V3 is desired, that cost $200.
Thanks John, I think I will play around with a free version till I make up my mind about the radio.
Good idea.
the only real difference is that the v3 allows multiple ops to connect at the same time.
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 263 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
