Stream Deck & FR Stack (latest version 3.1.35.65)
Hi all
I've had FR Stack on a pc where everything has worked, I have today installed FR Stack and Streamdeck on a new pc, loaded the plugin and the profile. The profile loads fine and shows the buttons that I exported from the working PC.
When pressing the buttons the green tick comes up (for muti action) but nothing is happening on the flex.
I have FR stack loaded and have mirrored the set-up etc from the working pc.
The ony difference is I have updated to the latest FR stack but don't think that should stop it from working?
Is the latest version working for anyone else? Am using 3.1.35.65
Rich
Perhaps the URL did not transfer correctly. Mark did update the StreamDeck Plugin, several revisions back, to allow you to enter multiple URLs, and then select the desire URL for you config.
Since you appear to be using FRStack and StreamDeck on the same PC, the correct URL will be:
Alan. WA9WUD
Hi Alan
I'm not at the station at the moment but will look tomorrow.
Would the URL not get exported when you export the profile? If not then great and I'm hoping this it it!
From what I can see, everything looks like it should be working, annoying when you switch to a different pc and it does work perfectly.
Rich
"Would the URL not get exported when you export the profile"
No, not if your previous Stream Deck REST plugin was not up to date.
Like I said, Mark revised the plugin to make it possible to enter multiple URL addresses. This was not the same in the older plug ins.
Here is a screenshot of mine. In your case, enter "http://localhost:13522/api" as URL #1:
Then, for each button, specify it should use URL #1
Hi Alan
Yep you were spot on, the URL had not exported from streamdeck, quickly added it and bingo, all working fine, should have spotted it so will know for next time.
Cheers
Rich
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
