Stream Deck Programming
Good Evening,
I was watching a youtube video on controllers for SmartSDR. The Stream Deck 15 key model seem to be a good choice at least for what I would want to use it for. Perhaps the 32 button model would be overkill at this point in time. I did see where one can go into FRStack, at least in the program direct and double click to files which helps in programming the Stream Deck.
That's the only thing that I am apprehensive about is the actual programming of the Flexradio functions I would want available on the stream deck. Is there anything documents or video's that you know of that would help to make programming the Stream Deck in the least painful way? Thanks
Mark Griffin, KB3Z
Mark,
I can help you remotely.
In FRStack there is a sample profile that can be loaded into the Stream Deck as well as the plug-in for using REST v1.2 commands. You then can move the buttons around and customize them.
In FRStack, under the Help menu is a selection for the View Rest Help. This is a complete list of all the commands for the Flex 6000 radios. Read all this carefully. After you install the plug-in that Dave mentions, it is all easy to accomplish.
I bought the 15-key Stream Deck and quickly learned that was a big mistake. There are so many things that you can do with the Stream Deck outside of Flex and FRStack. I now have the 32-key version and have many pages of functions on the keys (the Stream Deck lets you define folders that contain a whole new set of keys to display).
73, Craig KØCF
If you start using Node Red it opens up ability to control anything that Node Red can control. Relays, antenna switches, tuners, amps, rotor control, etc.
Also buttons to launch programs, create multi layer macros, send keystrokes. Really cool stuff.
I am very glad I bought the 32 button model of Streamdeck, Mark. Be careful that you don't get the 15 key model and wish you had got the XL. It is very easy to find a need for programming 32 keys. A small example:
Thanks Guys for all the suggestions and helpful pictures.
I purchased the 32 Button Model from Amazon today. It should be delivered tomorrow.
I will have to review everything in FRStack and if I need any help, I know you guys are there.
Thanks again!
Mark Griffin, KB3Z
Hi Mark,
let me know if you would like help to get set up before CQWW. Go FRC! My e-mail on QRZ is good.
Dave,
That would be great. I will email when I have the unit plugged into the computer. We have an informal FRC Meeting tonight and I work tomorrow during the day. Not sure if tomorrow evening would be good for you or not. My email on QRZ is good also.
Mark KB3Z
I'll drop you an email with my phone number. I will try to make the informal meeting tonight.
I just received my Stream Deck XL from Amazon. I have taken it out of the box and attached the USB cable and Stand. And it is now plugged into my Computer. I downloaded the Elegato Software and I have a Blue Welcome Light on the screen. I guess the fun begins now.
Mark KB3Z
Erik,
I like your Stream Deck Profile. Would there be a possibility that I could get a copy of it?
My Email is good in QRZ.
Thanks!
Mark Griffin, KB3Z
Hi Mark
Yes of course. I will send it today.
Erik.
Thanks Erik. I really appreciate that!
Mark KB3Z
Hi Mark,
once you get Erik’s profile loaded let me know if you need help customizing it.
Dave,
I haven't received anything as of yet. But as soon as I do I will write you an email.
Mark KB3Z
You should have received it Mark. I emailed it yesterday at 0851UTC to the address in qrz.com
With an attachment, maybe it went to your spam folder? Let me know if you need it re-sent.
Erik
Erik,
No, I did not receive it as of yet. I wouldn't think that the file size would be a limitation. Here is another email address that you can try, marktgriffin@verizon.net or pastormg2@verizon.net. I checked my spam folder and there was nothing in there.
Mark KB3Z
Erik,
I just sent you an email to your email address in QRZ.
Mark
Hello Mark
Yes, I received the email. I have resent the profile to both verizon.net addresses (2110UTC). The file size is 2MB which is nothing and, in any case, I have previously emailed this profile to many other Flex/Stream Deck users without a hitch. So I hope you get it this time. If not, let me know and I can send it to my Dropbox and email you a download link. Whatever the gremlins are, they will be defeated.
Erik.
I recently acquired the 32 button Stream Deck, have the Elgato software installed. Downloaded and installed the FRStack and a sample Flex routine. All looks good, if I click on the FRStack button, FRStack starts, connects to my 6600. For fun, I programmed a button to start Smart SDR and that works as expected. On the sample that I downloaded for Flex non of the other buttons fuction. If I select bands, then 80 nothing occurs. I looked at the button properties and I don't see anything that would allow me to make changes. Now the closest thing I've done to programming was building DB queries in Paradox for company training records some 25+ years ago. I have been looking at the various threads on Node Red, and I'm not sure if that is what I need to use to modify the templates for the Stream Deck or not. At this time I'm not into fully automating my station, just wat to start with being able to select different functions of the 6600 besides using my mouse in Smart SDR. Any and all guidance greatly appreciated.
Gordon0 -
Did you install the REST plug-in?
Good evening Eric, not sure. I used the FRStack and sample plugin from W3II.
So in another thread I found reference to using http://localhost:13522/api in URL 1 which was blank on all my settings. I put that in place and it seems to work. Though when I changed bands in one instance it started tuning, and I don't believe I had hit tune or MOX. Switched back to 80 metres on the stream deck and it changed back to 8-, though gave me an error then there was feedback through my external speakers. Managed to get rid of that when I restarted the 6600 as shutting down SmartSDR did nothing. On restart of the radio, the noise was gone, but it seems that Stream Deck software didn't save the input to URL 1. Put it back in and now it seems to have saved that configuration. Looks like first issue resolved, now to work on the customization further.
I didn't mention that it is Win10 Pro 64bit system running on Dell T5500 Dual Xeon 36GB RAM so lots of horsepower.0 -
OK, so yes you have it set up now. You must have installed the plug-in and that URL1 address is often missing when importing a Profile so you found that and fixed it. I do not think the error was SD related - it simply commands the radio as if you had changed bands in SSDR.
I have a 15 Key Stream Deck and have a set of Buttons that will switch me to the 5 60M Channels. Is there a way I can do this but also set the Mode, Filter, and etc like I can in a FRStack3 Button?
JoAnn - AB8YZ
Most certainly. Make a button a Multi Action, and put an action to 1. Set the freq, 2. Set the Mode 3. Set the Filter.
This is example is not exact, but shows Multi Action setting several parameters.
Would dearly love a copy of the master profile so I can understand the commands.
I'm having an issue right now with ATU.
Goal: Act the same as clicking ATU button in SmartSDR - what happens now seems to be an endless loop so not sure what other parameter I need to send to tell it to stop after its cycle completes.
I'm guessing in SmartSDR, it's an intelligent button to run, then auto-send a Clear message.
Any guidance appreciated!
Martin, KW1M in NH
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
