Spots menu
I have an issue with the Spots menu when I open it.
It opens shrunk down to its minimum size. I cant get drag handles to make the window larger but I can grab the top bar and move it around.
It has always worked fine. I did recently change video cards from a Radeon back to a Nvidia card. I have tried changing screen scaling off 100% and even messed with resolution to see if I could get the "double arrow" to resize. Moved it between monitors 1, 2 and 3 and no help.
Would rather not **** SSDR off if I dont have to. Any thoughts on dealing with this window? I did do a reinstall over SSDR with no success.
  • W2ECK
    W2ECK Member ✭✭
    Rich
    I had similar problem and fixed it. Search in community for “ can’t resize spots window” and my call sign. Scroll down and see fix Tim from Help Desk sent me
    73 Paul w2eck
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    Thank you Paul, will do.
    Rich kd0zv
  • Rich McCabe
    Paul, that worked. Thank you.
  • W2ECK
    W2ECK Member ✭✭
    Glad to hear
    73 Paul
