SWR meter reading
How do I get the PR/SWR meter to work when transmitting? I like giving reception reports but my SWR meter never seems to work at all. I can't see how to activate it.
  • Hal Massey
    Hal Massey Member ✭✭
    Answer ✓
    On my 6400's and 6600M you just tap the meters in the slice window and they rotate thru the various selections...depending on what computer hardware you have you may need to click them to rotate thru the choices. That takes you thru all the meter choices. Also, the radio control panel has them. As I type this I see Power at the top, SWR under it, then Audio level, then Compression level as we come down the radio controls screen. I hope that helps...
